I want to run this gauge as my only gauge... can anyone tell me what I would need to run this setup? http://www.summitracing.com/parts/ATM-6387/
I assume if it came with instructions, it would show you how to wire... our delimma would probably be finding vehicle speed.
That's not what I mean. A lot of these require a special in-line box to convert our speedo signal to one compatible with the speedo. I was wondering if anyone knew which one. I've emailed autometer directly... They said the gauge auto-calibrates to our system. So, I guess all I need is the gauge.
What year is your truck & is it a auto ,or manual trans?? I run Auto meter's manual Phantom gauges, & the correct senders,the speedo is electric & I have a 5 speed. Got a speedo drive that goes right on the trans from another company! I would run the matching gauge for oil pressure & water temp., as you should keep an eye on those!!
