just curious if anyone would be interested in my turbo setup ? I just want something I can turn my truck on and it starts every day and get good gas mileage since im getting my diesel pretty soon...heres what would be included... It works fine, nothing wrong with it, Im positive it is a good setup and will last if you dont push it with the boost. This setup ran very well for the few months I had it raping it every day, its just my motor had crappy pistons and the wrong rings and I blew it when I over heated it at 22psi boost... keep it under 15 it will last you a long time anyways heres what it is. not sure of the compressor size but it should be t24/t4 turbonetic waste gate intercooler with all piping 4 barrel 500cfm carb eddle brock oil pan with return line, oil feed line, steel braided throttle cable custom made 81 head for lower compression, may have bent valve not sure yet but for the right price I will have the head rebuilt for you and brand new turbo pistons and rings, they were installed but the truck hasnt been driven with them yet. Also what can come with it for more cash which I kind of want to keep for my next set up... turbo manifold, 3 inch down pipe, with some sensor on it I dont remember what its for though..., 3 inch exaust all the way to the back, hks ssqv blow off valve, greddy profec b spec 2 boost controller Ive got an extra 5 speed celica tranny as well... if you buy everything from me the only thing I absolutley recomend you get is a good electric fan and/or allum radiator !!! also good idea to buy better ignition like msd or something... if anyone is interested make me an offer well talk...
I am in Tampa FL. for the right price I will deliver any reasonable distance... which would probably be a couple hundred miles each way. Or I can ship.. should not be any more than 50 to 80 bucks to ship everything. This would be perfect for you to pick this up, while you rebuild your motor so you can build it the way it should be built for boost...Also If you need parts that meet oem spec and better for about the same price as ebay stuff I have a store local I can pick it up at.
sold right under $1,000 sorry I havent updated but it is sold, BYE bought the majority of the setup and someone local bought the rest.
