anyone turboed carb 22r
Discussion in 'Engine/Drivetrain' started by 2graphic, Dec 5, 2010.
  1. 2graphic
    2graphic Member
    auckland. new zealand
    1993 double cab
    i have seen it do but does anyone know anything about it?
    which holly carb?
    etc, etc??
  2. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    any carb jetted properly.
    any turbo sized properly
    tubing, ect, ect.
    did i answer your general question generally enuff?
    i have a carb'd supercharger setup, and i know theres at least pics of one turbo build here, search a lil bit and ask better questions.
  3. IronNam
    basically, supply sufficient fuel for the amount of air you add.
  4. 2graphic
    2graphic Member
    1993 double cab
    is it worth doing or just wasting time!
  5. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    its deff worth doing, I had it done to mine with a t3/t4 and an edlebrock 500cfm 4 barel... it was AWESOME. I would do it again but I cant find a cheap turbo manifold...
  6. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    waste of time.
    celing for a 2Xr is near 200hp, and thats still spending thousands of dollars.
    if your after power put a different motor in there.
  7. V8_TITAN
    Tampa Fl
    89 std cab
    deff not a waste, mine was backyard built and was nasty as hell. its a waste of time if you cant find deals on anything and pay someone for custom work... if you got a welder and can fab stuff go for it. or throw a v8 in for 1000 bucks and call it a day.
  8. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    nasty as hell for a 22r maybe.
    a stock 5m would still eat it alive.
    did you ever have it dyno'd?
    for a 22r my wagon is nasty as hell, can roast em in 3rd easy. but i know that the stock 1uz im putting in the stout would eat it. hell i bet the LS that motors in right now would destroy the wagon. if im lucky, i have maybe 150hp at the wheels, a cam, head work, better exhaust and ignition and i can maybe see 190. but thats another $2k on top of the $2k ive got into the motor. i already think its a waste of time, im not tossing much more into the motor.
    $4k with a 1uz could see 600+hp!! but for $1500 im getting a reliable 250hp, and V8 rumble, ill be happy...
  9. Comrade_Charlie
    Comrade_Charlie Veteran
    Rock Hill, SC. Charlotte, NC
    1973 Hilux
    I have a 79 tercel and i want to do draw through setup on it, Carb/turbo/intake/head. Do research on it, its definatly a tricky setup and probably more trouble than its worth, but for me its just another dumb project and I have all the parts except for a oil line. people made tons of power on it doing it on american cars, even I think the 1981 firebird came with draw through setup stock. turbos need to have carbon seals i think.
