any1 ever had problems with hids????got mine and they wont turn on
Discussion in 'Exterior/Body' started by lowyota, Feb 19, 2011.
  1. lowyota
    lowyota Newbie
    i order the 100w kit from hidsgeeks.com everything is plugged in right ...changed the fuses like it said and i got nothin....the hids r good i checked them by hooking them up straight to the battery......any suggestions????? if i cant figure it out im gonna hook them up on a switch runnin straight off the battery
  2. lowyota
    lowyota Newbie
    meant to put this under 89-95
  3. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    I see more than one complaint about this company!:shrug:
  4. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    Did ya put a stock bulb back in to make sure its not a problem wih your truck?
  5. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    probably shouldnt have ordered a 100w kit... why they even have those beats me... 35 and 55 are plenty and 55w will melt your foglights in some cars
  6. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    Id call them up and run through some trouble shooting questions with them. Ive installed a few HID kits the only problems Ive ever ran across is the wiring actually be reversed (which would cause them to not turn on) and bad ballasts which would also cause this but not if you have directly hooked them up to power source. Id double even triple check the wiring harness is correct as far as the plug/wire you connect to the ballast harness. Other than that call them up and ask. Also I agree with Titan 100w kit is kinda overkill hopefully you bought the projector headlight housings for them if the kit did not already come with them as you will eventually burn if not melt the factory headlight lenses.
  7. jetas
    did u wire them to a relay?? 100w kit? why??
  8. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    when i installed them on my chevy dually i hooked the power into the ballast box backwards. all i had to do was flip the plug and they've worked perfect ever since.
  9. lowyota
    lowyota Newbie
    im runnin the stock lights now....only reason im runnin the 100w....there bighter than the 35 an 55 ...and im running the black projecter headlights figured id loose light so figured id get 100w kit to make up for it....the kit i got says i dont need a relay its just a plug in kit that i would just have to change my fuses from a 10 to 20 amp
