another new guy
Discussion in 'Introduce Yourself' started by [email protected], Aug 26, 2009.
  1. mayonick1169@yahoo.com
    [email protected] Newbie
    hey guys... i gotta 87 toyota been and trying to find the best way to lower my truck im sure theres plenty of ways... i dont want the stock stance but just a little lower what do yall prefer?
  2. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    welcome!
    cheapest: blocks and loosen your torsions.
    more exspensive: spindles and drop leafs
  3. nvrenufedge
    nvrenufedge Grand Toyotaholic
    Caldwell, ID
    bagged '93 std cab
    Welcome to TM! Have any pics of the truck?
    I recommend using drop spindles in the front. You'll maintain most of your factory ride. I did Belltech 2" drop spindles in front, 3" blocks in back, & Toxic drop shocks all the way around.
  4. mayonick1169@yahoo.com
    so if i move the torsion ill have to get an alliment?
  5. Shadetree Mechanic
    Shadetree Mechanic Addict
    Emerald Triangle, CA
  6. burnzya
    bodied 73 hilux
    your supposed to get an alignment after any suspension adjustment. i don't.... i just deal with the crappy tire wear.
  7. mayonick1169@yahoo.com
    hell yea... kinda short on cash but ima make it work... ima get some pics on here soon
    kinda ugly but work in progress
  8. Shadetree Mechanic
    In that case I'd highly recommend doing a ball joint flip and lowering the torsions combined with removing the middle leafs in the rear. Total cost: $00.00 Add some lowering shocks if you have $160 or so as that is an investment you will want with basically any type of lowered suspension you go with in the future.
  9. mayonick1169@yahoo.com
    sounds way to easy man.... dam
  10. Shadetree Mechanic
    It is really that simple. The torsions can be a bit of a pain to get adjusted. You might want to trim the bumpstops down in the rear so it doesn't bottom out so easily, but yeah, that's one of the great things about Toyota minis. They have some great cheap tricks you can use on them.:waytogo:
  11. mayonick1169@yahoo.com
    i allready did a motor swap and got a 4 speed took the 5 out
  12. mayonick1169@yahoo.com
    ok well what about the upper part
  13. nvrenufedge
    Caldwell, ID
    bagged '93 std cab
    what upper part?
  14. Shadetree Mechanic
    I didn't bother flipping mine. You might want to flip it if you are concerned about keeping your steering geometry as close to stock as possible, but with the level of drop you are going to have you are not going to be binding the knuckles or anything, I really don't think it matters if you flip the upper or not. It doesn't matter for drop. Just the lower control arm that is attached to the torsion affects ride hieght.
  15. nvrenufedge
    Caldwell, ID
    bagged '93 std cab
    oh, control arm. The torsions will work fine for a simple drop, shouldn't it?
  16. Shadetree Mechanic
    The ball joint flip is just gravy on top of whatever drop you get from the torsions. It doesn't hinder ride quality at all and doesn't make you bottom out any quicker. If nothing else, flipping the lower ball joints would be .75" less you'd have to lower the torsions to maintain a better ride.
  17. bustedknuckles
    bustedknuckles Enthusiast
    Las Cruces, NM
    1985 Toyota, 2000 S10 Xtreme
    Welcome to Toyota Minis. All of our trucks are a work in progress.
  18. MacRib
    MacRib Enthusiast
    San Diego
    90 4runner, 94 standard cab, 90 standard cab STOLEN
    We flipped the upper ball joint to help keep the camber even...
  19. mayonick1169@yahoo.com
    sounds little more safe
  20. Shadetree Mechanic
    I actually kinda like the small amount of negative camber I got from flipping my lowers...:shrug:
