Another fitment question...
Discussion in 'Wheels/Tires' started by Under Construction '93, Jan 12, 2013.
  1. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    In a month or so I'm buying a set of 20's for the mini. Boss 328 black 20 x 8.5 with a +38 offset 6.18 backspacing. I assume these will be ok offset wise, but am wanting other opinions as I dont want to run into problems. Truck will be Z'ed soon and has 4x4 front.The 18's i have now are +40 7.5 wide and sit in a bit and rub a little @ full lock wich is more than stock as I cut off the steering stops for bags(and didn't need to. lol :eek:) Any help is greatly appreciated.
  2. yankeetaco72
    yankeetaco72 Veteran
    Escondido
    82 short /97 Tacoma
    I know Im no help but Ive got to say if those are the 20s youre going with they are sweeet!:waytogo:
  3. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    Yessir! :D
  4. Litneon
    Cocoa, FL
    94 xtra cab
    Yeah those are BOSS! hahaha!
    ....but yeah. I think that offset will work. I bought +42mm offset and then added 25.4mm spacers effectively making them +17 or so. My rears are +20mm 9.5"
    When I bought them, the retailer told me that everyone runs a +42mm, but when I installed the fronts, they were way too far in, especially running the 4x4 fenders.
  5. CrazyCody93
    CrazyCody93 Enthusiast
    Gresham OR
    84 Sr5 Xtra cab
    they will still rub but only like yours do now, where its just at Steering lock
  6. IronNam
    350Z rear 18x8.5 with +30 offset would be your comparison.
  7. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    Thanks guys. Guess I'll just deal with the rubbing on lock.
  8. IronNam
    what part does it rub on?
  9. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    I think the strut rod.its been so long since i dealt with it.lol
  10. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    So unfortunately I cant get those 20's after all (long story) Manufacturer out of stock, finish issues, and no answers etc... Now I'm looking at some TSW vortex's which I will powdercoat black as they arent available in black.
    Anyhow... these are 20x8.5 also but have a 40mm offset. My understanding is the higher offset sets the wheels back in the wells more, so, ideally I would want lesser of an offset like 30 ish right?I dont want to run spacers either. They come in a 20mm offset too it looks like.Any help is greatly appreciated again guys. Thanks.
  11. WinksYota
    WinksYota Enthusiast
    In the dirty south of Sandy D
    1993 yoter single cab
    Told you.... my 20's rubbed all over... strut rods. Cab. Frame.. WAY to big for a lil truck.... IMO
    I have a 9 inch rim with +22 offset... its got room all around and rear needed minor trimming hope that helps
  12. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    My options are 40 or 20 offset. Someone gimme the green light, im thinking 20. Gonna order these today.
  13. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    Im gonna run a 18x8 with a +42mm. I ran that by Steve at Cando or what used to be Cando and he said +42s should tuck nicely.
  14. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    Those will be sucked in pretty far. Litneon bought same offset and runs spacers. I bought mine today. +20 OFFSET 20x 8.5 $1200 plus I gotta powdercoat 'em and buy tires. Yikes!
  15. Xs5875
    Xs5875 Addict
    Greenville, Ga
    What backspace?
  16. TwinTurboTaco
    TwinTurboTaco Enthusiast
    Space
    92 2X
  17. Xs5875
    Xs5875 Addict
    Greenville, Ga
    Very cool calculator..
  18. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    You didnt BUILD your truck around 20"s bro. Im tubbing my firewall as well as ordered low offset wheels and wont have a strutrod soon enough... There is plenty of bagged and bodied yotas rolling around with no issues on 20"s.
  19. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    So I picked these up in the 20mm offset and I think they are way to close to the fender in the front. the rims alone touch the fender half turned unless i'm at full lift. Gonna have to swap em out for 40mm i guess. So frustrated right now, thought I'd get more answers on here. Since litneon had a higher offset than me I figured I was in the safe zone. Also I think 40mm will get me less than an inch more so I dunno. Any ideas? :shrug:
  20. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    You could always go fenderless :evil:
