Alternative Coil Spring Set Up
Discussion in 'Suspension/Chassis' started by Seventy6Celica, Oct 9, 2010.
  1. Seventy6Celica
    Seventy6Celica Member
    San Gabriel Valley
    75 Hilux
    Just some FYI. A while ago I was at the junkyard and noticed that 83-97 mighty max springs were real similar to the toyota springs. After some quick measurements it turned out they were the same OD and ID. The only difference is they are about as tall as the stock toyota spring with 2 coils cut. So you will get a drop just switching to mighty max springs. Or you can get Belltech lowered mighty max springs and really go low. Here is a picture of the Belltech mighty max lowered spring (left), stock mighty max spring (middle), and the stock toyota spring with 2 coils cut off (right).
    Here is the end drop with the belltechs installed. I will try to get some better pics tomorrow.
    I don't know how much of a drop it is since I never measured the truck with the stock springs. By the way, the tires are 185/70R14.
    Also, I put in some Tokico shocks from a 67-69 Camaro.
    The tokicos are a little fatter than the KYB's or stock shocks, so you have to massage the opening in the lower control arm just a hair to get the tokicos in.
    In my opinion, the truck drives a million time better. The ride is solid and stiff, but not harsh or bumpy. You will have to remove the swaybar and the lower metal bump stop brick, but it's a small price to pay for an awesome suspension setup.
  2. Kevintothej
    Kevintothej Member
    Lebanon, OR
    1971 Toyota Hilux & 1971 Toyota Hilux
    That's awwsome!! Goin to get a set of Mighty Max springs Thursday.
  3. Seventy6Celica
    San Gabriel Valley
    75 Hilux
    Here is the installed picture.
  4. CurtisZ
    CurtisZ Addict
    Lake Stevens, WA
    1978 Pickup Longbed
    Any idea if this works up to the '78 model year?
  5. Seventy6Celica
    San Gabriel Valley
    75 Hilux
    If it's a coil spring, then yes.
  6. CurtisZ
    CurtisZ Addict
    Lake Stevens, WA
    1978 Pickup Longbed
    Yeah, coil spring. I just did not know if they changed the springs between the years.
  7. StupidSheet
    StupidSheet Addict
    Canada
    Where did you buy yours? Got a link?
  8. Seventy6Celica
    San Gabriel Valley
    75 Hilux
    I got them from www.autopartsdealer.com. You have to search for belltech part number 4270. They were the cheapest by far. I also got the shocks from them too. Those are tokico part number HE3346A.
  9. StupidSheet
    StupidSheet Addict
    Canada
    Cool Thx!!!
  10. mrwizard
    mrwizard Member
    Boise, ID
    1970 Hilux
    So I've got an RN-10, 1970 Hilux...are the coil diameter/height the same as yours? In other words (the infamously lame noobie question), will these Belltech's work for me? Thanks a ton guys.
    R
  11. Seventy6Celica
    San Gabriel Valley
    75 Hilux
    As far as I know they will work, but I'm not 100% sure. Someone else might want to chime in on this one.
  12. garagedoorman
    garagedoorman Addict
    north georgia
    great find 76. That deserve an ataboy. Thanks for sharing
  13. Seventy6Celica
    San Gabriel Valley
    75 Hilux
  14. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    Too bad cannot sticky this thread or something. In 3-4 months going be lost in the archives
  15. mrwizard
    mrwizard Member
    Boise, ID
    1970 Hilux
    seventy6, could you measure the diameter of your coils so i can compare them to my '70 hilux's?
  16. Seventy6Celica
    San Gabriel Valley
    75 Hilux
    I will get you the measurement tomorrow.
  17. Seventy6Celica
    San Gabriel Valley
    75 Hilux
    The diameter is 4.5" OD.
  18. mrwizard
    mrwizard Member
    Boise, ID
    1970 Hilux
    rock on...thanks. i've got to go measure mine now. i appreciate it tons!
  19. koich
    koich Member
    San Jose
    1971 RN12
    Maybe we should start accumulating some parts info and data onto a spread sheet per chassis type? I'm curious to learn how much carried over from the pre '71 model to post.
  20. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    bet money they do.
    this last weekend i measured my stout springs vs 78 hilux springs. will work fine, only slightly concerned about the top of the spring cuz i cant see it, but thats nothing a torch or angle grinder cant solve.
    on topic-ish:
    78 corona and older front springs will work too, slightly softer spring rate, with a slightly taller spring.
