Aftermarket Torsion bars
Discussion in 'Suspension/Chassis' started by Toyo Trucker, Sep 23, 2009.
  1. Toyo Trucker
    Toyo Trucker Addict
    Hi everyone,
    I need bigger, stronger torsion bars. Can I run 4wd torsions?
    Can someone send me some aftermarket links?
  2. rajzswap
    rajzswap Addict
    CA
    89 2jz pickup
    Yes, this was covered not to long ago. 4wd torsions work and Sway-a-way sells aftermarket ones as well
  3. Toyo Trucker
    Toyo Trucker Addict
    Rajz... you happen to know the specs on the torsions????
    2wd?
    4wd?
    SAW?
  4. Toyo Trucker
    Toyo Trucker Addict
    Toyota Truck Torsion Bars
    MAKE / MODEL YEAR DIAMETER LENGTH PART No. MSRP
    Toyota 2WD 84-97 25mm 35 1/8” 1636 $220.00
    Toyota T100 4WD Up To 92 25.5mm 35 7/8” 1638 $200.00
    Toyota T100 2WD 93-97 25.5mm 34 3/4” 1639 $295.00
    Toyota 4WD/ 4-Runner 86-97 25mm 41 7/8” 1646 $220.00
    Toyota T100 4WD 93-97 25mm 41 7/8” 1646 $220.00
    Toyota Land Cruiser Diesel Application 32mm 47 5/8” 1660 $700.00
    Toyota Land Cruiser/ F-100 31mm 47 3/4” 1661 $700.00
    Toyota 2WD 300M Race Application 93-97 27.5mm 35 1/8” 31636 $600.00
    Toyota 4WD 300M Race Application 86-95 / 93-97 27mm 41 7/8” 31646 $600.00
    Anyone know if I can run the 300M 2wd race application on my truck???
  5. carbedrn4spd
    carbedrn4spd Member
    Charlotte, NC
    89 standard cab carbed
    i have no idea if they will or not but why the he** would you spend 600$ on torsion's? i mean unless you wanted a racing application
  6. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    Stiffer ride maybe?
  7. Megaglow_Z
    Megaglow_Z Addict
    Benton la
    81 long-bed goodness
    True. 600$ would go a long way towards bagging your truck. unless your just wanting to stay static permanently.
  8. Toyo Trucker
    Toyo Trucker Addict
    I don't plan on spending $600 for some race application torsions. I just need to know if they will fit my application.
    I do need a stiffer ride. What brands are out there?
    OM EMU
    Sway A-way
    4wd option
    Hellwig (i think)
