After Torsion Bar and Leaf Removable Drop... *PIX*
Discussion in 'Suspension/Chassis' started by phatmitzu, Aug 11, 2008.
  1. phatmitzu
    phatmitzu Veteran
    SoCal 626
    93 Standard Cab 5spd
    Crank down my torsion bars and removed the center leaf.
    Here is before...
    http://www.toyotaminis.com/forum/showthread.php?t=916
    This is now...
    Now my driveshaft(not axles) is rubbing my center cross frame...Any C-Notch kits out there you guys recommend? Or should I just to a half-moon pipe?
    :cool:
  2. lownloud
    lownloud Toyotaholic
    Plains, Montana
    Depends on how much it is rubbing . . . If its justa lil which it sounds like, take the bed off & plasma cut a notch for the shaft, itsa really strong crossmember, so justa lil cutting wont hurt it, hell Ive seen many rigs with about 6" cut all the way outta it . . .
  3. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    your going to bounce like hell and want your torsions back lol ! looks good.. Im afraid my rims stick out to far or I would pull a leaf myself !
  4. phatmitzu
    phatmitzu Veteran
    SoCal 626
    Cool. Yeah, its just rubbing a little. It needs an inch or two more for clearance. I'll cut out a notch...maybe weld a half moon pipe to protect the driftshaft...just in case it bottoms out. I have my bump stops trimmed to a minium.
    I didnt remove the torsion. I just crank it down a bit.
  5. patriotpop
    patriotpop Addict
    Baltimore, MD
    94 2wd
    Looking real good!!
    Your running 17's correct?
  6. phatmitzu
    phatmitzu Veteran
    SoCal 626
    Thanks. Those are 16 x 8.
  7. cEElint
    cEElint Enthusiast
    Bakerstink, CA
    '91 Yota STD
    looks good.. you make me wanna start on my truck.. haha.. mine are only 16x7s though.. i wanna find some basically the same off the Crown Vics.. they have a fatter lip
  8. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    Id just go with the half moon pipe & weld that in. I had that same problem on my 88 standard cab...cut some pipe, welded it in & it fixed the problem! :)
  9. phatmitzu
    phatmitzu Veteran
    SoCal 626
    Coo, I'll do that.
    Any of you upgrade the sway bars? or add another set of shocks?
    By no means I'm trying to make my truck a track racer, but I would get rid of as much body roll as possible...
  10. Dcups
    Dcups Addict
    Seattle
    93 Std Cab chassis/4Runner 2door body
    How does it ride now?
    I have a set of front and rear sway bars but yet to install them. still sorting out some electrical gremlins i have after my swap
  11. IBeSeeN
    IBeSeeN Addict
    Harrisburg, Oregon
    89 Toyota
    what type of shocks you running now? i have belltech nitro drop 2's on mine now and they are nice
  12. Predracer
    Predracer Toyotaholic
    Conyers, GA
    Long bed 80 2rz turbo machine
    Did you have to have your front end alighned after you did the torsion bars?
  13. patriotpop
    patriotpop Addict
    Baltimore, MD
    94 2wd
    Oh yes, most certainly!!!!!!!!
  14. Predracer
    Conyers, GA
    Haha yeah I figured
  15. yotarip
    yotarip Veteran
    Your truck looks realy good. It's making it hard for me NOT to paint my truck semi-flat black. I'm leaning toward satin red since my truck is originally red anyway.
    Love the sportmax wheels on your truck.
  16. phatmitzu
    phatmitzu Veteran
    SoCal 626
    It rides decent, but I was just wondering what other improvements can I make to make the handling better.
    I have white KYBs right now.
    Not yet. I'm going to leave the alignment last after I finish all the suspension mods. Then its onto the motor...
    Thanks yotarip,
    Satin red should look hot.
  17. V8_TITAN
    Tampa Fl
    89 std cab
    yeah I didnt get an alignment and its been almost a year and my tires are all even...
  18. blazinrola80
    blazinrola80 Member
    told you it would look better if it was dropped more.. looks hot..!!!
  19. Steve@CanDO
    Steve@CanDO Member
    NOR-CAL
    94 Toyota Standard cab
    Heope this might help
    Hopefully these will help. This is the pics from the Project Anti-hack also know on our myspace.com/candoinstalls as Bradys Toyota if you want to see the step by steps
    Then the guys built this sweet raised floor section. I remind you though this truck lays rocker on 20's. So you might be able to use our idea here but limit it to just under the cab floor, if your not bagged or going to be bodydropping it.
    PS
    By the way that's 1/2" plate I used. Kinda over kill, but we don't take any chances. My guess is 3/8 would still be plenty strog. The reason using flat bar is to get as much clearnce but still want to keep the strength there the factory intended
    Regards,
    Steve
  20. phatmitzu
    phatmitzu Veteran
    SoCal 626
    That is a sweet set-up!
