I had this erratic shaky idle. Looked at Service sched it said Valve lash every 15K inspect/adjust. Set piston1 to TDC 0degrees (check on dist cap) remove valve cover. Check valve 1 & 2, 4, 6 (numbered from front to back) rotate engine 360 degrees then check 3, 5, 7 & 8 all of them were too tight since the valvejob so I had lash adjusted @ .007 intake and .011 exh COLD slapped everything back fired her - no spark - oops forgot the dist cap fired her what the heck is that sound? oh chit i forgot the rachet on the crank pulley Fired her up again, warmed up idles WAAYYY quieter and TONS smoother. no more shakes!!! I enjoy driving my truck that much more!!! This is part of the reason I prefer working on an old truck. ALways something to do, so i never get bored of it. Next I'll attack the front end alignment with a set of 14" alloys and tires I found for CHEAP.
