Acronyms
Discussion in 'Frequently Asked Questions' started by Justin Danger, Jan 24, 2017.
  1. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    So after a while of being on this site i have noticed that a lot of acronyms are used, and was hoping to compile a list of them for easy reference. Some of these may seem straight forward, but as long as it helps someone not feel like an idiot, it will be worth it.
    ATF: automatic transmission fluid
    ABS: antilock braking system
    BFH: Big frekin hammer
    BJ: Ball joint
    CARB: usually in all upper case refers to the California Air Resource Board (Smog laws)
    DJM: DJM suspension parts
    FBI: Fender Bender International (made bumper adapter brackets, but are out of business)
    FSM: Factory service manual
    FWIW: For what it is worth
    HID: High intensity Discharge (headlights)
    IIRC: If I recall correctly
    JDM: Japanese domestic market
    LCA: lower control arm
    LCE: LC Engineering (performance parts supplier)
    LSD: limited slip differential
    LTB: looking to buy
    MPH: miles per hour
    ODO: abbreviated for "odometer"
    OEM: original equipment manufacturer
    PM: private message
    PS: Power Steering
    RPM: revolutions per minute
    STD: abbreviation for "standard"
    T-Bar: torsion bar
    WTB: want to buy
    These are just what I put together in a few minutes, please if you can think of any more, add em to the list!
    Cheers all,
    Justin Danger
    Mikerocosms likes this.
  2. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    Just like a textbook, internet forums should have a "vocabulary" section, hahaha.
    I don't think I ever heard the word "stanced" before coming to this site, I still don't understand what it means aside from being lowered (and with your wheels sticking out past the fenders?).
    Some other quick ones that come to mind, in no specific order:
    TRD - Toyota Racing Development
    SR5 - Toyota trim package. Believed to mean: "Sport" "R-series" "5spd"
    CAT - catalytic converter
    CAM - camshaft
    ECU - engine control unit
    EGR - exhaust gas recirculation
    TPS - throttle position sensor
    AFM/MAF - air/fuel meter, mass air flow sensor
    IACV - idle air control valve
    o2 - oxygen, oxygen sensor (o2 sensor)
    R&P - ring and pinion
    GTS - Google that shiz
    CL - CraigsList
    UTE - "utility vehicle"/truck (term common in Australia/NZ)
    18r, 20r, 22r, 22re - Toyota "R" series engines
  3. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    adding to it....
    ECM- engine control module
    VAFM- Vane air flow meter
    -- yes i know ECU is up there already, but some people use the other.
    MAP -manifold air pressure
    "DIFF" - referring to either front or rear DIFFERENTIAL
    BJF - ball joint flip (cheap mod performed to lower front of vehicle)
    IGN -ignition
    STA- starter
    "DIZZY" - referring to the distributor
    "A/F" or "AF" - air/fuel, in reference to air-fuel ratio
    Tstat -thermostat
    HC - heater core
  4. jetas
    BHG-- blown head gasket
