a real technical torsion bar question
Discussion in 'Suspension/Chassis' started by pig rig, May 30, 2010.
  1. pig rig
    pig rig Enthusiast
    bow washington
    so Im thinking of reclocking my torsion bars so heres my question
    if I loosen up my bars and pull them and then set my truck at ride hight then putt the bars back in I should have it set back to have the same firmness in the front like stock and keeping my lowered stants correct
    with that being said I could also raise my a arms up alittle so I could stiffin it up some if wanted
    help me with my thinking and correct me If Im wrong
  2. jetas
    Just make sure the torsions dnt have a guide on the splines. Otherwise ur guna have to grind it off
    but yes u could do it how ur saying but its guna be hard to judge when its guna stay at that height. just re index them, take it off the jack/jack stands check height. tighten or loosen the torsions to ur liking..
  3. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    yes and no...you can achieve that ride stiffness, but remember when you lift your truck up the suspension sags a bit then lifts off the ground. The torsions twist, and thats what gives you your stiffness. If you were to just put them in when the truck is at ride height, they would sag ( twist ) and lower the truck more, but you would get the same ride as stock. So you are just going to have to play with it.
    Also I think the stock torsions have a keyway in em, you are going to have to grind it out of the key..
  4. Litneon
    Cocoa, FL
    94 xtra cab
    Yeah, but that doesn't make a whole lot of sense logically. You won't change the firmness by raising or lowering your suspension. Making it stiffer can only be achieved by changing T-bars or physically topping out the suspension on the bump stops and preloading the bars.
    I know what you are saying, but re-indexing the bars only makes sense if suspension is capable of traveling further than the bar will adjust to.
    Say you wanted to lift the truck, then you might want to index them, but since you can lower the truck all the way to the bump stops without running out of adjustability, it won't make a hill of beans.
    Usually the ride gets "stiffer" not because the ride IS stiffer, but because it bounces off of the bumpstop so easily, resulting in ESS (Ejector Seat Syndrome).
  5. dillinja666
    with turning the torsions keys though it does make it ride softer from what ive felt...softer until you bottom out lol
  6. Litneon
    Cocoa, FL
    94 xtra cab
    It physically can't unless you unload the bars against the upper bumpstop.
    Unless you change the leverage acting on the bar, a constant weight will always twist the bar the same rotational angle. Doesn't matter what angle you index it to, until you hit a suspension limiter, ie. bump stop.
  7. IronNam
    When you "loosen" the torsion bars, you are DECREASING the SPRING RATE. This lowers the ride height.
    When you "tighten" the torsion bars, you are INCREASING the SPRING RATE. This raises the ride height.
  8. Litneon
    Cocoa, FL
    94 xtra cab
    Again, you can't change the spring rate. Adjusting the key only changes the angle of the key and the LCA equally. If their centerlines are parallel, they will remain so until contact is made with a bumpstop.
  9. pig rig
    pig rig Enthusiast
    bow washington
    ok I think I got my question answerd
    litneon I think I understand what your say'n but if my understanding is correct the way a torion bar suspension works is one end of the bar is staionary and the other end flexes with the movement of the suspension so by lowering the truck Ive relaxed that flex or by raisn it Ive removed the flex thus a stiffer or softer ride and when I say flex i mean it in a twisting motion
  10. jetas
    You probably could get a stiffer ride but you wud have to re index the torsion key but it would only make u go higher. So to counter that drop spindles/arms/bj flip would be necessary.
    Just get the SAW torsions....
  11. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    This is correct. The amount of spring in the steel is constant. The angle of the control arm stock is close to parallel. When you adjust the torsions they aren't parallel and the ride suffers. Raising the truck with the torsions gives the same ****ty ride as lowering with them.. Re-indexing only helps with the ground clearance.
  12. Litneon
    Cocoa, FL
    94 xtra cab
    Yeah, I wasn't going to go there yet, but you are right. The more angle you have on the A arms (or any suspension linkage), the more of the energy gets transferred straight into the frame instead of being absorbed by the spring/shock combo.
  13. pig rig
    pig rig Enthusiast
    bow washington
    ok Im understanding what your say'n now so as far as my question goes it is wat it is and the only way to help the ride out is to put better shocks on it and then live with it
  14. burnzya
    bodied 73 hilux
    You can change the torsions to aftermarket, they will have a different spring rate. Doing spindles and drop control arms will give you a stockish ride.
  15. pig rig
    pig rig Enthusiast
    bow washington
    yea that stuff cost money something I'm a little short on right now
