A/c stop blowing cold air
Discussion in 'Maintenance/Repair' started by FOKAI12, Jul 29, 2009.
  1. FOKAI12
    FOKAI12 Enthusiast
    GREW UP IN GUAM NOW IN VA.
    1992 Reg Cab
    What should I check for since my A/C stopped blowing cold air all of a sudden. It used to blow very cold air and yesterday it just stopped.
  2. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    could be a ton of things..does the compressor turn on? you could of also sprung a leak
  3. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    check to hear if the compressor comes on.
    if it does, then check to see how often it comes on and off....... if its real quick like constantly on off then theres no charge in the system and likely got a leak...... you running r12 or r134?
