i am new here can you all help me i am trying to remove my a/c cluch how to do that i have bought a new one i have a 1992 toyota pickup 2.4 l 5 speed thanks in advance
Remove the nut in the center of the clutch hub, remove the belt, and it should slide off, might take a light tap from a SOFT hammer, its keyed on the shaft. The inner part, bearing, pulley has a snap ring to remove plus the ground and energizer wire and it slides off too. They have shims behind the outer clutch to adjust the clutch clearance for proper engagement.
