A/C Condenser compatibility
Discussion in 'Parts and Accessories' started by HALMS, Dec 30, 2013.
  1. HALMS
    HALMS Enthusiast
    Guam
    93 reg. cab, 95 reg. cab
    Does anyone know if a A/C condenser from a 1992 (R-12) will work on a 1995
    (R-134). I just found out that the evaporators are different, tried to install a 92 evap. into my 95 and the pipe/hose connections are different. I can get the matching pipe/hose, but I'm afraid the same problem will arise on the condenser side. Would hate to waste my time, but I'm trying to save some money at the same time. Thnx
  2. HALMS
    HALMS Enthusiast
    Guam
    I figured it out somewhat, so in case someone else tries to swap out there evaporator, the hook up high/ low sides are different on both the evap. Side and condenser side. Weird thing is the part number is the same for 89-95 evaporator. I broke down the housing to see if the expansion valve could just be swapped over, but no luck.
    So either I get the ends cut and welded to match, or I'm gonna see if the piping from the drier is the same, if so I will swap out the system from the drier outlet to the compressor inlet.
