95' Toyota Truck. $1200.
Discussion in 'Vehicles' started by 22slow, Sep 25, 2013.
  1. 22slow
    22slow Member
    San Diego during the week, and Az on the weekends.
    1990 2WD Sb and 1982 4WD Lb
    95' 2WD shortbed pickup for sell. Oil pump siezed and the engine now has a rod knock. The engine will need a rebuild obviously.
    Has a few goodies. LCE cam, fresh Enginebuilder head, ARP headstuds.
    Brand new timing set from Enginebuilder. New chain, gear, cover, water pump, oil pump etc..
    Bucket seats from 4runner.
    I will include a brand new 9LB Fidanza Flywheel with brand new clutch.
    The truck also has a brand new Stereo with new speakers. Still have the reciepts.
    New tires!!
    All the truck needs is a fresh engine, and it will be awesome. I can even include an extra 22re with the asking price of the truck if you want it.
    I will have pics up soon.
    Email me at [email protected]
  2. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    sup sean! you back already?
  3. 22slow
    22slow Member
    Not yet, but close. Just getting a head start on things. I need money to fix the 4x4.
  4. SD YOTA
    gotcha man... i guess no 2jz swap huh...?
    well, ill spread the word out around here n see if someone wants to pick it up. i know its a clean little rig. is it still registered out of cali?
  5. 22slow
    22slow Member
    As much as I would like the 2JZ swap, I scrapped the idea. The truck is actually registered in AZ. It really is a nice truck. All of the front end bushings have been replaced, along with the shocks. It steers straight, with no play in the steering wheel.
    Originally, I thought the engine noise was the timing chain slapping on the timing cover violently, so I bought a whole new timing set with new cover, oil pump, water pump, chain, gear, steel backed guides, etc.. I tore the engine down, and found a seized oil pump instead, and then I knew the internals would be toast......but the whole front end of the engine is new!!!
    I bought an Alltrac instead. Cheaper, and I needed a clean DD so I can tear down the 4x4 and rebuild it.
    Thanks. Ill hit you up when I am back in town.
    Ill be tearing apart the front axle in the 4x4 to replace the destroyed trunion bearings.
  6. SD YOTA
    for sure man... just hit me up!
