94 yota Pickup, How do i remove the whole bed?
Discussion in 'Exterior/Body' started by RosaMorado, Dec 6, 2010.
  1. RosaMorado
    RosaMorado Newbie
    Newport News, VA
    94 Toyota Pickup
    Can anyone tell me how to remove a whole bed cover? :eyecrazy:
  2. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    There are bolts you can find from bottom of bed/frame remove them remove bed done if you want pics I can do that too
  3. IronNam
    About 8 bolts using 14mm heads.
    3 on gas tank tube thing
    Rear tail lights removed.
    Remove wires from bed.
    Licens plate too.
    It'd be easier if you just go lay down and find out.
  4. jetas
    wat nam said
  5. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    yep its very easy, you can crawl under there, figure it out and be done in less than an hour for sure, its super easy.
  6. layedout94
    layedout94 Enthusiast
    aberdeen
    94 toyota hilux
    Or u could just cut a big hole from wheel well too wheel well then u don't have too look under u can see from up above .. Don't worry you don't even need that part of the bed it over rated...lol..that's wat I did
  7. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    ^^ that's what i did
  8. eurofreak2002
    B-town 208
    Yah I got a huge hole too but its cause my notch and bridge took it over not for easier access to bed bolts but it is nice
  9. RosaMorado
    RosaMorado Newbie
    Newport News, VA
    94 Toyota Pickup
    alright sounds good thanks! ill see how it goes when the damn snow is gone..
  10. USDMRN8
    USDMRN8 Newbie
    City By The Sea Long Beach, CA 562
    89' Single Cab - RN8
    Ironnam isn't it 17mm bolts or does this vary mine were 17mm I believe :thinking:
  11. Litneon
    Cocoa, FL
    94 xtra cab
    Really? You're asking possibly months ahead of time? Haha. ;)
    If I remember correctly, they may be 19mm bolts. I seem to remember them being the same socket that I pull the wheels with.
  12. IronNam
    14/17/19mm, either one of those lol. You might be right, I think I used a deep socket 19mm. I just know I used a 1/2" drive and tons of PB Blaster.
  13. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    Dual 17s for mine. All 7 nuts and bolts :lol:
