94 project, should be sweet
Discussion in '1989-1995 Build-Up/Project Threads' started by akprigge, Sep 21, 2015.
  1. akprigge
    akprigge Newbie
    sup boys, I just got my 1994 pickup a few days ago. it's a little rough but it's a project which is what I wanted. it's pretty much a base truck, has A/C tho which I don't really need in Alaska. my plan was to build my Sierra and get something to drive while that was going down but I got into toyotas and now I'm building one and driving the Sierra. the truck has 237000 on it but after a new front crank seal, oil change new coolant blah blah she runs sweet. plans for the future go something like this: all bodywork/paint at school, some sort of buckets, new steering wheel, some 15x10s, hydro e brake, locker, and I could go on but well see how far I get.
  2. Radchadtrinidad
    Radchadtrinidad Member
    Anchorage, Alaska
    86 pickup
    Nice man! It looks like you need new headlights. I can give you some spare ones if youre in anchorage
  3. akprigge
    akprigge Newbie
    yeah thanks man!
  4. akprigge
    akprigge Newbie
    so i got the 3 in drop blocks in today at school. ran into a bit of a speed bump, the hole on the bottom of the block was too small for the head it was supposed to sit on. took them over to small engines and drilled them out no big deal. didnt have enough time to do a torsion drop tho. is a torsion re-key a good idea if im already down there messing with it?
  5. madstriker
    madstriker Member
    Las Vegas, Nevada
    2008 Toyota Tacoma
    Good luck on your project. Can't wait to see the result of your hard work.
  6. jetas
    Yes rekey the torsions while youre there. Hit the nuts and bolts with PB blaster or something and let it soak up before you start
  7. akprigge
    akprigge Newbie
    got some stuff done on the truck at school today. bought a set of 5 steelies from my teacher for 50 bucks! also got the oil changed and dropped da torsions, will do a rekey later just didnt have the time. heres some pics of it and the neglected daily
      File size:
      36.2 KB
      63
      File size:
      52.2 KB
      59
      File size:
      23.3 KB
      68
  8. akprigge
    akprigge Newbie
    so my grandpa has started an auto parts/performance store her in anchorage in 1976, and has owned operated it ever since. i was there yesterday and decided to take a look upstairs where i haven't been in years and I'm glad i did because i hit the centerline jackpot! some of these wheels are so old they were shipped to the shops old address! when i asked him about all these wheels he told me i was welcome to anything up there so i checked all the boxes and found exactly what i was looking for, AUTO DRAGS :meemee: and luckily they're 5x114.3! i scored 2x 15x8.5 and 2x 15x10! the 10s are a little wide out back so I'm thinking of running some kind of flare in the rear, any suggestions? PICSSSS!
  9. akprigge
    akprigge Newbie
    More pics
  10. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Sweet score. I wouldn't worry about any flares, I'd be hunting down a rear axle from a 78ish truck. It should be about 3" narrower than what's in there now. Toyotafiberglass.Com does make a dually type flare for your generation truck though if you're dead set on that route.
  11. akprigge
    akprigge Newbie
    i do kind of like the look/idea of a flare on the rear, and toyota parts aren't too common up here so it might be a better route. ill look into those flares
