94 22re timing chain tensioner fail
Discussion in 'Engine/Drivetrain' started by mumalik, Jan 24, 2011.
  1. mumalik
    mumalik Newbie
    i have replaced the timing cover and timing set and my chain snapped after 2 weeks of replacing it so i replaced the timing set again because the tensioner failed the first time now 2 weeks after the second swap my tensioner is not working any clues as what it could be i bought my timing set at autozone
  2. IronNam
    engnbldr.com
    he'll have you covered and help you better than autozone can
  3. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    did you put it on the right way ? I have no idea ?
  4. Nook
    Nook Addict
    oregon
    Upper and lower gears on the right direction??? top bolt in oil pump is the correct length not binding tensioner?? overtightening the tensioner distorting it?? a few ideas to start with.
  5. cgeorge
    cgeorge Newbie
    I bought my chain and misc. parts from engnbldr.com
    I'm about 6000 miles into it and all is well.
  6. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    When you put the new chain on did you put on a new tensioner or did you leave the old tensioner with grooves in?
  7. IronNam
    I'm about 40k since i did my timing chain install, i think. maybe 30k
  8. ShortyzKustomz
    ShortyzKustomz Enthusiast
    Central Va.
    94 Single Cab
    Something must've been wrong man, I did mine with a company on ebay Full kit (timing cover, metal guides, gears, chain, oil pump, water pump ,and everything else) for under $200 and havent had a issue at all, and came with a warranty too!
