93 Toyota fuel problem
Discussion in 'Engine/Drivetrain' started by Gearhead, May 13, 2013.
  1. Gearhead
    Gearhead Newbie
    I have a 93 22re Toyota sr5 pick up. Truck stalled while driving on freeway, got it towed to my house and have done some trouble shooting on the system. Gas tank is half full, motor will crank over fine but not start. If i hold open the volume air sensor door on the air box the truck starts and runs, i even drove it around the block and it ran OK. I tried a new volume air unit and it still will not start, i check the connector plug to the unit and it is getting 12 volts. what else should i check or change out ? Truck has 202,000 miles on it and was running fine before it stalled on me.Any help would be appreciated. Thanks
  2. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    did you try another air flow sensor?
  3. IronNam
    is that intake pipe not worn through?
  4. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Check opening circuit relay under dash buy kick panel think on passenger side . They had a corrosion problem/ heat opening the Maf all the way triggers the fuel pump/ecu efi open circuit wire.. tricking the truck to start thru full voltage ........you can also jump the connectors n toyotas to bypass this relay but its been a minute sense. Recall doing that
  5. Gearhead
    Gearhead Newbie
    Tried a a new relay same thing will not start. there is 12 volts going to the relay, open the door all the way truck starts right up. What should i try next?
  6. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Opening circuit relay tested good
    Check efi relay there wired in sequence on connection 4 then check tps for voltage battery on motor off
  7. Gearhead
    Gearhead Newbie
    efi relay good. i have no voltage to tpi sensor with key off, and 4.0 on the green with yellow trace and 10.0 on the white with blue trace wires with key on.
  8. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    could be the reference signal from the air meter not going to ecm -tells the ecm when to turn fuel pump on.
    ...so... when u hold the afm door open, it sends extra fuel = starts vehicle.
    check ALL VOLTAGE SIGNALS from afm.
    just a thought.
  9. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Try the jumper test I listed jump b+ and Fp with wire then key on reach under Mas sensor and push door open should here the fuel pump run try closing door se if it cuts off ......these are just some elimination testing this bypasses the ecu control over the fuel pump .
  10. Gearhead
    Gearhead Newbie
    did that pump turns on. Voltage at connector to the mas sensor was 4.0 for ref. and 12.0 for power.
  11. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Hmm and your not getting any check engine lights/codes
  12. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Reference wire seems kinda low did it change when you swung the Maf door open say like 5 to 9 volts
  13. Gearhead
    Gearhead Newbie
    No check engine lights or codes. Will recheck ref sig voltage and let you know.
  14. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Also check your ecu if you can get it open look at the circuit bored for hot spots mainly the little brown capacitors they bust and leak onto the bored causing problems . I no some of the capacitors are related to voltage flow to the maf sensor
