Hey guys can anyone tell me where to start measuring my rear shock if I needed to get measurement for shorter ones I think my standard shocks are bottoming out, I got my leafs reset so im not using lowering box as im from new zealand we are only allowed to use 2inch blocks with out a cert.
how much total drop are you running with the leafs? if you are running around 3" of drop in the springs, you will want to run about a 2" shorter shock than stock. lowering blocks will not change your shock travel but leafs will.
