92-95 4runner corner lights are different...
Discussion in 'Off Topic' started by IronNam, Aug 2, 2009.
  1. IronNam
    different than other 4wd corner lights?
  2. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    yes....... its because of the composite headlamps they use. different length wrap around. since the early 90 trucks and 4Runners still used a 5x7 sealed beam light, the grills were different. unless you run the same 4Runner composit, you will need the early style corner to fit.
  3. IronNam
    hmm, so its not possible to modify them at all to fit?
    I think i can try...
    anyone have early style 4wD corners?! I got a pair of 92-95 4runner corners! lol
  4. SD YOTA
    we tried it with Mac's truck and they are obviously larger than the early style.
    the headlights on the 89-91 and 92-95 have different distances between the corner and the headlight on the 4runners and 4x pickups.
  5. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    and trying to use a 4runner grille with 2wd corners is the same fun little battle. i tried that. grille ended up being junk. lol. you can get them on ebay cheap. do you want clears or ones with orange?
  6. IronNam
    hmmmmm, now that you asked which one... i cant seem to decide..
    who favors what
  7. IronNam
    so, all 4WD pickup corners are the same, but the 89-91 are the same as all 4WD pickup corners, correct?
  8. SD YOTA
    all 89-94 pickup 4x4 corners are the same.
    90-91 4Runner corners were the same as pickups 89-91.
    92-94 4Runner corners only fit those 4Runners due to the different hedalights.
    if you got 89-94 toyota 4x4 pickup corners, they will also fit the 90-91 4runners.
  9. IronNam
    Ah, alright, was trying to clear that up! Thanks man
