91 toyota 2wd for sale
Discussion in 'Vehicles' started by danthepoolman, Oct 11, 2010.
  1. danthepoolman
    danthepoolman Newbie
    low country south carolina
    91 toyota pickup 2wd
    I have 1991 toyota pickup for sale it has a 22r lc engineering stage 2 motor 9.5 to1 compression polished intake&valve cover dual weber 40mm sidedrafts ported&polished cannon intake stage 2 cam head shaved 10 thousands over sized s.s.valves heavy duty valve springs stage 2 port&polished head mls head gasket block was bored 40 over arp head studs d.u.i street&strip h.e.i.7000 rpm distributor 40,000volt coil live wire ignition wires lc high volume oil&water pumps lc dual row timing chain under drive pulley kit adjustable timing tag flex lite flex fan new radiator&hoses carter fuel pump lc performance header cat back exaugst with polished tip optima red top batt. in cab tach 9lb.fadanza flywheel spec stage 2 cevlar clutch&pressure plate new slave&master cylinders lc short shifter drag 17inch rims brand new nexas n3000 tires bucket seats all k&n filters spare block&cylinder head 2 valve covers carb synch tool this motor has about 1000 miles on it i have over 4800.00 in the motor parts and machine work alone i was going to mini this truck but my mud/hunting truck has bad rings will also consider trades for performance suzuki samurai 1.3 or 1.6 motor this is a strong truck great daily driver mini truck prodject or motor would be great for dirt track racing
  2. andrep6810
    andrep6810 Member
    Miramar, Fl
    94ext 2jz
    Photos?
  3. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    Need photos
