THIS SETUP WILL NOT WORK ON BASE MODEL PICKUPS WITH A TWO PIECE DASH! THIS WILL ONLY FIT 4RUNNERS AND PICKUPS WITH A ONE PIECE DASH.. Many sellers state that this will fit the Toyota pickup also, but fail to tell you that there is a slight difference in fitment on the SR5/4runner one piece dash and the base model pickups with the two piece dash. The difference on the base model is the way the bezel curves around to meet the glove box. Not making it identical with the curve on the upper dash where to two meet. I found this out when trying to install this in my base model pickup..The base model pickup w/two piece dash has its own specific bezel ( THIS IS NOT IT )... Included is a clean matching Gray Ashtray and the correct Factory Radio Mounting Brackets w/ Compartment as well.. The Bezel condition is very nice but missing the Lighter and Ashtray hardware ( simply use the hardware off of your old broken Bezel )... The condition of the Radio Mount/Compartment is great as well but there is a small hole drilled in the back of Compartment ( Possibly for a wire for the addition of other electronics ). Not visible when installed in the vehicle. You can check my feed back on ebay %100. KERTWOOD1 Thanks for looking. $45 via Paypal, Shipped to your front door. [/URL][/IMG]
Yes I know... they are from a '92 Ford Taurus... a guy here on the forum made it work on his truck so i am following what he did... once i get it to fit i am sure it will be functional. The stock cup holder would spill onto my Kenwood radio so this would be a great idea since it will be below it.
