'89 8" diff in '77?
Discussion in 'Engine/Drivetrain' started by first80toyota, Jan 20, 2014.
  1. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    So a good deal popped up on craigslist for a 8" 3rd member out of an '89 pickup, but I'm unsure if I can use it in my '77?
    Are they compatible?
  2. eighty_D
    eighty_D Member
    Fairbanks, AK
    '79 SR5 2wd lwb
    The 8" 3rd member isn't compatible with the 7.5" housing. You could probably swap in the whole axle assy with a little fab though.
  3. first80toyota
    Pacific Northwest
    '77 Hilux
    My truck has an 8", and I bought an 8" third member... I was unsure if the newer diff would work in my older axle.
  4. eighty_D
    eighty_D Member
    Fairbanks, AK
    '79 SR5 2wd lwb
    Compare pinion flange its the only change iirc. Maybe someone more knowledgeable will chime in.
  5. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Early (pre 84) flanges have 8 mm bolts and a more rectangular pattern. Late (post 84) flanges have 10 mm bolts and a squarish pattern. Swapping flanges is easy or you can simply drill the early pattern into the late flange with no issue.
