88 Rear Window Problem
Discussion in 'Exterior/Body' started by KK082409, Oct 13, 2009.
  1. KK082409
    KK082409 Enthusiast
    Pasadena, CA
    88 single cab
    I have a slider in the rear and am looking to replace it with a solid window. Will this be an easy switch or is there going to be some modifications needed? Thanks for the help.
  2. rajzswap
    rajzswap Addict
    CA
    89 2jz pickup
    I just started a thread not even a week ago about this. But to answer you question, you just need to find the vehicle with the same year, model, etc.. and they switch right out, as I was told. I am going to be doing mine as well so ill let you know.
  3. JOE_1985
    JOE_1985 Veteran
    87 custom
    from what i read the extraslab rear glass is differnt than the regular slab
  4. 89dlx47
    89dlx47 Veteran
    st. louis
    89 standard 2wd
    yes make sure you get the right one, if you have a reg cab and get the extracab it wont work, and vice versa. i did mine on my 89 at the begining of september and its super simple to do, my advice is to get a hayne work book and it will show you everything to do it
  5. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    if you dont have some sort of interior panels in the way, its just a matter of folding the inner lip of the seal over the cab flange til its out. then start by kinda tucking it in and folding it around. i have a couple modded screw drivers this works great for.
  6. 89dlx47
    89dlx47 Veteran
    st. louis
    89 standard 2wd
    ya the screw drive works great to get the old one out but wat i did to get the new one in was took a thin piece of rope and put it in the weather stripping channel, then pulled it from the inside of the cab
  7. Megaglow_Z
    Megaglow_Z Addict
    Benton la
    81 long-bed goodness
    That's the way the pros do it :cool:
  8. KK082409
    KK082409 Enthusiast
    Pasadena, CA
    88 single cab
    Thanks guys...... This will be my next project once I get back truck back from having everything shaved. Was supposed to get it back today but he ran into some difficulties so wont get it back till tomorrow. Cant wait to get started on the rear window.
