88 EFI wants to idle high
Discussion in 'Engine/Drivetrain' started by StupidSheet, Nov 22, 2010.
  1. StupidSheet
    StupidSheet Addict
    Canada
    Just wondering what sets the high speed idle on these motors? Is it the temp sensor? It seems it doesn't want to come off high idle now that it's getting colder. I never had that problem last winter. Anyone have any ideas on what to check?
  2. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    could be....... if its still sending a "cold" signal to your computer its probably leaving the cold injector on tossing the extra fuel.....
  3. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    Cold air valve underneath the TB...
  4. StupidSheet
    StupidSheet Addict
    Canada
    Hard to get at that valve? Is it common for that to go?
  5. B.Y.E.
    B.Y.E. Toyotaholic
    1982 2wd Hilux
    Can you verify which type you have? Your looking for 2 small (1/4") coolant lines attached to it...
    The older version is electronically controlled VS the newer mechanical type that sits underneath the TB...
  6. StupidSheet
    StupidSheet Addict
    Canada
    Hmmm, ok I'll see what I can find tomorrow.
