84 lux change to 60mm spigot front hubs?
Discussion in 'Suspension/Chassis' started by AE25, Mar 24, 2014.
  1. AE25
    AE25 Newbie
    Auckland NZ
    84 xcab sr5 ute
    Not having any luck.
    i have an '84 hilux 2wd ute and wanting to use cheap rims. (gets parked in dodgy areas). there's plenty of later toyota's with 5x114.3 stud pattern with oem wheels available but they tend to have the smaller locating spigot like found on altezza's, mark2's etc and later hilux's. And i kinda bought some mark2 rims with new tyres which i like alot but didn't fit the spigot. then went bought some 2007 hilux 15" steelies but they had same issue :duh:
    To use wheel spacers requires around 30mm thick to clear the bearing housing but that thickness is illegal here so not an option.
    Question: is there a simple front hub swap from another vehicle to drop from 67mm spigot to the 60mm?
    Or do i sell up and spend more on aftermarket rims. :cry:
    cheers
