well I found a trans for my truck and this should have nice gear ratio has any one ran once of these in there truck do they fit IE tailing housing being different I have 2 to choose from 82 and 84
they may run the closer but taller gears if it's a W57 or 58. The shifter housing may need to be swapped for the one on your truck (so the shifter doesn't come out in your sheet metal) otherwise should be the same. Check the build plate and find out what transmission it has but it probably won't be much different gearing-wise than our truck's 5 speed. 1st 2nd 3rd 4th 5th W55 3.566 2.056 1.384 1 0.85 (2wd trucks, celicas, supras, IS300) W56 3.954 2.141 1.384 1 0.85 (4wd trucks) W57 3.285 1.894 1.275 1 0.861 (celicas, supras, cressidas) W58 3.285 1.894 1.275 1 0.783 (later supras, cressidas) Sorry, columns got jacked up.
well I want to move my shifter back that is one of the big reason for this swap right now and for the life of me I forget what my rear gear ratio is, I will have to check my vin and sadly no vin form these trans since there stocked on the shelf from what gather, all 3rd gen toyota trucks have the same gear ratio and from what I know. I can see it taking a big toll in power I am mostly wounding about the drive shaft will it fit once i do the lex v8 swap I will not care to much
reeeeeeaaaallly... I might have to find me one of those. 3.07 rear end with the W55 is bad for launches but puts 5th where it oughta be.
my truck came w a W55 (same as celica) but beware -if ur truck originally had the 4spd, then the new 5spd will need minor fab work -the rear mount, and the shifter hole. u have to use the drive shaft that came with the 5spd trucks to mate properly w the new trans. --at least, thats what i'm told/what i've experienced.
all buy the trans but all swap it in when I get my 1uzfe for now with the 22re the close ratio is what it needs both the w56 and w58 are the same size
