83 toyota brake booster
Discussion in 'Engine/Drivetrain' started by Miagy671, Apr 18, 2013.
  1. Miagy671
    Miagy671 Member
    Everett washignton
    1971 Toyota pickup
    Would a 83 booster fit on a 71 hilux??? Can anyone help me
  2. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    Not sure. But an '82 booster fit on my '93. So, odds are on you side.
  3. riceratyota
    riceratyota Veteran
    backwoods oklahoma
    which one 77/78/79/81[r.i.p]82 sbrc driftbox, and a CeliLux/current daily= 79 sbrc [lil' blue]
    most likly but i would use the master as well most likely a upgrade worst case slot the bolt holes in the firewall just make shure to measure brake rod stroke to make shure your not over or under adjusted
  4. williyumz
    williyumz Enthusiast
    90-02 4runner master fitted my 71 booster, i'm guessing an 83 booster should fit with little effort
  5. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    i put an 81 booster and master into my 78. changed to some nissan truck crosspin arm on the pedal side, but the enginebay side had no issues.
