83 Auto/Longbed Stalls..Help!
Discussion in 'Engine/Drivetrain' started by lakes73, May 11, 2011.
  1. lakes73
    lakes73 Newbie
    noob here...83 longbed..2wd..Auto trans...i just got the truck..106k..replaced the plugs,wires,cap,rotor,air/fuel filter/set timing..the problem is..when the truck is warmed up she will idle at about 800 rpm..but when i put her in drive or reverse the engine will start shaking..the rpms will drop and she will act like she want`s to stall,but does not..any ideas on what to check next?..any advice would be good..thanks in advance,Chris
  2. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    Vacume lines
    Check all Your vacume lines.
  3. lakes73
    lakes73 Newbie
    83,Auto want`s to stall,shake when put in Drive...
    I checked all the lines..Can`t find a leak...I love the truck,but i hate to drive her because it shakes so bad when I`m stopped at a red light..It doesn`t stall out but the idle drops real low...When i put the truck in park or neutral,the idle goes up to normal..anything else can i check next?..Thanks again,Chris
