80 yoda
Discussion in '1976-1983 Build-Up/Project Threads' started by 1uz_yoda, Jan 5, 2015.
  1. 1uz_yoda
    1uz_yoda Member
    Bremerton, WA
    1980 long bed
    So here we go,
    Been looking to start this for a while.....
    So the truck is a 1980 longbed had a 20r in it has a removable hardtop shaved
    handles and tails
    The plan for the truck is to finish the 1uz swap and bag it.
    Picked up a 1uz outta 92 SC and w58
    My buddy has a powder coating set up, so i bought him a sixer and some powder and started coatin
    Got some mounts in
    Paired those with so bomb proofs
    Then i found a screamin deal on some compressors
    Those will sit on the shelf for a little while, but cant pass up a sale
    Finally decided to start thining out the harness
    Then the rain let up so i decided to pull the 20r and trans out...
    Out she comes and there she goes...
    Cleaned the bay up a bit and pulled the trucks harness into the cab
    And then some rain...
    But you cant let a little rain scare you away
    There's the uz's new home
    So the to do list:
    -Finish melding the truck's harnes to the uz's
    -bolt the trans up
    -install drive line
    -install radiator and fans
    -buy/install fuel pump
    That sums up most of what needs to happen to finish the swap...
  2. jetas
    That motor looks right at home. Im surprised it just dropped in
  3. tylerzettner
    tylerzettner Member
    Jerome, Idaho
    82 Hilux
    why the hell did you make it a convertible??
  4. 90DailyDriven
    90DailyDriven Veteran
    New Mexico
    90 standard cab 2wd short bed
    Why did you swap the oil pan setup? Is there a clearance issue with the older trucks?
  5. 1uz_yoda
    1uz_yoda Member
    Bremerton, WA
    1980 long bed
    yea it dropped in no problem, but I didn't install it with the trans so that probably helped, and it was pretty tight with the brake booster being right there.
    and there might be a issue with hood clearance
    haha yea Washington weather doesn't permit a whole lotta use from it, but i bought it this way.
    i got it off a guy who brought it from CA. when i got the truck i put in the 20r with the side drafts and the header. the top is super easy to install and remove it just donest like to sit in the rain for days on end.
    but since i have the UZ in, i can move it back in the garage with the bikes.
    I got a real good deal on the UZ and trans with the adapter from a guy who was gonna swap it in a corolla wagon, he traded the original one for one of a LS400.
    it dropped in just fine, BUT i had to remove the steering dampener, i was hopping i could just extend the bracket a couple inches and remount the dampener.
    in my research, there are a few AUS companies who make rear sump pans, but i didn't know if it was worth the time to try and get one
    Lexus V8 Engine Rear Sump | Lexus V8 Products & Services | J&M Lexus V8 Engine Conversions
  6. 1uz_yoda
    1uz_yoda Member
    Bremerton, WA
    1980 long bed
    Truck is back in garage
    Maybe ill get the trans in tonight..
  7. yotarip
    yotarip Veteran
    Hello fellow 1uz swapper. This makes me happy. Where did you get your mount from? It looks like an Xcessive Manufacturing piece. Did it mount up well?
    One word of caution when altering the harness. I have done this on two 1uz swaps and both times I ran into idle control valve issues. I believe I removed a needed wire both times. On the other three 1uz swaps I performed without altering the harnes, the motors idled perfectly. I haven't spent the time figuring it out yet. I just rigged the ICSV to hold the idle at about 700-800. Makes cold starts hard.
    Good work. Your gonna love this motor in your truck.
    BTW,
    The SC400 1uz has a rear sump. I'm suprised the front sump you have cleared the x-member. A sc400 sump may allow you to mount the engine lower if you have issues with the bellhousing clearing the trans tunnel.
  8. 1uz_yoda
    1uz_yoda Member
    Bremerton, WA
    1980 long bed
    Yea they were xcessive mounts paired with trail gear bomb proof
  9. yotarip
    yotarip Veteran
    Well Damn. Good to know.
    Thanks
  10. 1uz_yoda
    1uz_yoda Member
    Bremerton, WA
    1980 long bed
    Haha shoot,
    I wanted to get rid of all the auto trans connectors .....
    But, ive already thined out the harness.... According to:
    This article from lextreme-
    Lextreme: Lexus-Toyota V8 Forum
    And
    Myabe thats the 1000cc cold start injector? I left that all attached and intact...
    But i guess ill find out once everything is hooked up and im ready to start it up
  11. 1uz_yoda
    1uz_yoda Member
    Bremerton, WA
    1980 long bed
    Yea i bought this set up from a guy who was gonna swap it into a corolla wagon, he traded out the rear sump for a front sump,
    The big mount issue i had was the steering dampener
    And there is another issue with the front sump and no flex plate
    So if i can find one, ill get a rear sump and change it out...
    Or i have couple buddies who are pretty good with fabbing things up i might do something like this
    And build a small inspection plate to cover the flywheel hole...
  12. ace89
    ace89 Member
    vallejo,ca
    86 xcab sr5 turbo
    nice build.. i love the side drafts you took out
  13. Aircooled
    Aircooled Member
    Kansas
    81 Pickup, 83 Pickup
    Yes! I will be the process of doing this in the next couple months. Its good to know the Xcessive mounts do work on our trucks! Will be following this!
  14. 1uz_yoda
    1uz_yoda Member
    Bremerton, WA
    1980 long bed
    thanks man,
    the side drafts were a tons of fun, but i wanted a little more lol
  15. 1uz_yoda
    1uz_yoda Member
    Bremerton, WA
    1980 long bed
    yea i was super stoked to find out that there was bolt in combo
  16. 1uz_yoda
    1uz_yoda Member
    Bremerton, WA
    1980 long bed
    small update :
    worked on the cover plate for flywheel
    used some card stock to mock it up
    then transferred to a piece of aluminum and cut it out
    did the test fit up
    so ill do a little trimming... and then paint it up.
    it should be sufficient to keep out rocks and any thing else thatd want to hit my flywheel...
  17. 1uz_yoda
    1uz_yoda Member
    Bremerton, WA
    1980 long bed
    also cut out the battery tray and inspected the rust
    anyone have good input for the new battery location? since the air filter will end up in the stock location
    i was kinda just thinkin about putting on the drivers side
  18. eighty_D
    eighty_D Member
    Fairbanks, AK
    '79 SR5 2wd lwb
    Get a battery box and bolt it in the bed?
  19. yotarip
    yotarip Veteran
    I installed a honda civic battery on the diverside.
    I even used the honds battery tray (after some trimming) and tiedown.
  20. Nito_13
    Nito_13 Newbie
    Awesome build collecting parts for my own do still have the side draft setup and are looking to sell it
