7mgte swap help!!
Discussion in '1989-1995 Build-Up/Project Threads' started by SevereScorpio, Dec 12, 2014.
  1. SevereScorpio
    SevereScorpio Newbie
    I'm doing a 7mgte swap in my 1994 2wd toyota pickup its 5speed and I'm getting all i need with the motor except 5m motor mounts metal head gasket and arp main head studs (ill be them once i have everything) i need to know how much firewall will need to be beat back and how much notching the radiator support will need to go forward and where i can find a oil pan to fit it I'm not lifting my truck i like it lowered thanks and in advanced i could probably use a wiring diagram for the wiring harness thanks
  2. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
  3. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    Mid sump oil pan.
    1/2-1" clearance in a few specific spots.
    No rad support mods necessary....need slim elec fans.
    Heard wiring is simple.
    Check the links in the link above. One is a 2wd swap, the other is 4wd. Everything is the same, accept 2wd needs the "mid sump" oil pan.
  4. Blacklightnin55
    Blacklightnin55 Member
    Louisiana
    1990 Ext-cab
    Check out utube "wiring a 7mgte" only need about 4 wires to get it running.
