79 brakes
Discussion in 'Suspension/Chassis' started by rphamil, Apr 12, 2011.
  1. rphamil
    rphamil Newbie
    vb, ark
    79 sr5
    Would any other rotors and drums mount up to stock 79 calipers and spindles
  2. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    What are you trying to do?
    Vented rotors? Or are you planning on going big?
    Big brake setup is not easy, but I found the headache is well worth it :waytogo:
    And to your question, Im counting on no. 8inX 0.5in rotor that has the specific hub design. Not likely.
  3. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    75-83 spindles and brakes are more or less the same. 75-78 and 79-83 just need to swap side to side to orient the tie rod arm of the spindle properly. If you're looking to upgrade from the crappy stock solid rotors, theres been quite a few good write ups.
  4. rphamil
    rphamil Newbie
    vb, ark
    79 sr5
    Just trying to do something cheap work at a parts store and kinda hard to find anything decent just cheap stuff. Mostly just want vented thats it
