That's rad. Was it an rv that somebody capped the cab back on? Does it use the one rim with two tires setup in the back, or two rims? Anything done to the motor? You should slam it and keep going with the rat rod look its got started. Welcome to the site. What part of Nevada you in?
Yeah it used to be a rv. The back has been sealed up with sheetmetal. The rear duallies are 1 piece. You have to get a little creative to break the inner beads, but once that is done they come off pretty easy. Motor has a Weber carb on it and it has been side piped. Emissions stuff is gone. Thanks for the welcome! I live in West Wendover, NV.
