76 PickUp -> No Spark --> Ignitor? Or??????
Discussion in 'Engine/Drivetrain' started by Lostandconfused, Mar 13, 2012.
  1. Lostandconfused
    Lostandconfused Member
    Here's the update, People of TM Land ----
    I pulled the number one spark plug from the engine block.
    No spark.
    I'll replace all four plugs. They look a little fouled. Then I'll try it again to see if I get spark.
    Thus far:
    * The battery is strong. 12 volts and 600 cranking amps.
    * The engine turns. Not frozen.
    I hope I haven't fried the ignitor. :verdict_in: That's over $400 to replace! So before I go out and get another, I'll work my way back from the spark plugs.
    I'll see if I get spark at the plugs.
    I'll check the distributor cap => clean and adjust.
    I'll check the wire from the coil--> spark?
    How do I check to determine if the ignitor is working?
    I have power to the red wire, but after that I'm not sure what to do....
    Thoughts and suggestions please.
    I really don't want to junk this truck, but I gotta get it going.
    Thanks!:clapping:
