76 hubs
Discussion in 'Suspension/Chassis' started by Steelaworkn, Aug 20, 2012.
  1. Steelaworkn
    Steelaworkn Newbie
    Camano Island WA
    1976 Pick-up
    So, still putting the 76 together. The old hubs seem like they've been over-heated several times and some of the bolt holes common to the Rotor and Hub are damaged. Thinking about several repairs for them:
    A. upsize the bad holes and go with bigger bolt
    B. helicoil the bad holes and keep same bolt size
    C. replace them with new
    D. replace them with used
    Availability is an issue and strength is another issue. What did you do, what are you doing, what would you suggest?
  2. Immoreradthanu
    Immoreradthanu Enthusiast
    Spokane, WA
    79 long bed
    It depends on how much you want to spend? I don't know how much new ones are but would be my best bet along with. Ew wheel bearings. Buying old ones runs the potential of them being warped as well. And the other two options seem like a quick fix to get it by till ulyou can fix it right. But you have to think you probably need to replace the rotors if you drill out for bigger bolts. All up to you but i think i'd pony up for a new set of hubs and bearings.
  3. rink45
    rink45 Enthusiast
    vancouver, wa
    78 shortbed
    I have a used pair in good shape I'd sell ya for 40 bucks plus shipping... would need your zip to check
    shipping cost
  4. Steelaworkn
    Steelaworkn Newbie
    Camano Island WA
    1976 Pick-up
    If you could email a few pics that would be great. I might even be able to come down and pick them up in person. we're up on Camano Island.
  5. Steelaworkn
    Steelaworkn Newbie
    Camano Island WA
    1976 Pick-up
