74 corona wagon $1k obo
Discussion in 'Vehicles' started by ShoNuff, Dec 3, 2012.
  1. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    $1000 obo (trade see below)
    Seattle, WA, 'merica
    1974 corona
    50k ish miles on chassis
    all trim and my corona parts stash included + extras
    sat for a VERY long time outside, then was spray painted 8yrs ago...lots more "patina"
    very few dents, normal rust (front of rockers/rear wheel well lips)
    bad crack in original windshield all other glass is good
    100% unmolested wiring/body
    mods:
    4/3 drop, cut springs newish shocks
    84+ 22R, weber 32/36
    dt 4-1 header 2in exhaust
    81 celica 5speed, a W50 i think, but whatever was in a 81
    SACHS clutch, turned flywheel 5-10k ago
    81 celica 2 part driveline with home made xmem
    96 saturn SC1 90amp alt
    complete 5 speed swap with factory parts, new master/slave 2yrs ago
    electronic ignition
    78 corona wagon tailgate with wiper/harness, factory switch
    powder coated chrome hood louvers
    the bad:
    needs a windshield and window seals
    carpet is destroyed/missing
    cracks on dash, holes in seats
    small cut on the tunnel for the shifter
    carb is F'd, runs but wont idle.
    electrical is funky, works but has moods.
    it sat for a good 25 years outside
    loud top end on motor
    radiator very functional but mounted ghetto
    needs tires
    but wait there's more:
    perfect front bumper
    roof rack w/slats
    auto brake pedal/shifter
    auto and manual center consoles
    87 truck carb and intake w/emissions setup totally functional...
    3/4 original hub caps on close enough to stock 81 celica wheels
    this is a project car, it needs some work im not trying to hide it. would like to see it to a good home and will have tons of current pics and video very soon daylight permitting. i have a complete build thread on it from day 1...
    here:
    super goon warning: lots of pics
    a couple old pics
    current...more asap
    things id trade for:
    honda 50cc most anything functional
    35/13+/15 wheeler tires
    yota 2wd air bag stuffs
    cash
    HD projector
    8ch+ mixing board
    synth's/drum machines/samplers
    and if your still reading... thx.
    this is the quick sale listing, if not gone soon its going on ebay no reserve
  2. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    NOTE: THIS HAS THE SAME SUSPENSION SETUP AS A -78 HILUX, DRILL A COUPLE HOLES FOR BALL JOINTS AND HAVE 5 LUG, BIGGER BRAKES, DROP SPINDLES, ECT
    more pics!
    note: all the wheels are 14x5.5 stock 2nd gen celica steelies, rears are painted black and look smaller. all tires are old, that why it needs tires. they do hold air with not much dry rot. standard 4x114.5 lug pattern.
    drivers side hub caps are original with a 1 extra in back, passenger side is 78+ corona
    as i stated above, it does come with powdercoated chrome louvers in the hood (not installed yet) does not come with the original hood that was crunched, current hood is straight as can be.
    WILL NOT COME WITH COLLECTOR PLATE OR LICENSE PLATE FRAME!!!!!
    lots more parts to add to this pile tomorrow, and a complete list of em.
    stock 87 22r carb/manifold/egr in the box with all the emissions crap cept the air box, all functional.
    also note the rust hole in the floor, caused by a leaky windshield, similar hole on pass side
    mileage is off by -5-10k, speedo didnt work before, does now but is off, reads fast.
    radiator DOES NOT LEAK! but the radiator arms are 70% not attached, radiator is mounted solid with lots of safety wire. this motor/trans was built from spare parts i have lying around...
    problems with carb:
    needs adapter plate gaskets (sealed with copper spray not rtv)
    primary carb shaft stripped on the nut, did the best ghetto fix i could, but still leaks (vac). also there is no choke, PO broke the bolts to the choke and bent the choke butterfly shaft with a ghetto manual setup. i have removed the choke shaft and butterflys.
    questions? pic requests?
    more pics, parts and info tomorrow, thanks for looking
  3. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    i am willing to ship this car, expect $1k ish to the east coast or so
    as promised more pics of parts included and a list.
    semi complete list of stuff included:
    totally functional emissions friendly 87 truck carb and intake with all the fixins
    perfect front bumper w/bumper guards
    roof rack w/slats
    auto (tan) and manual (grey) center consoles
    glove box in grey
    all missing exterior trim
    complete steering column w/delay wiper switch and all ignition stuff w/key
    3in drop cut hilux springs
    perfect but needs paint trim panel thingy behind the front bumper
    non electric black front seatbelt set
    grey and black steering column covers, i think i have lost the original brown one
    78 gauge cluster panel
    78 grill and 1 headlight surround
    auto brake pedal w/bracket n shifter
    unmodified gas pedal
    and the louvers, need some polish
    may be a few more things floating around, i am a horder...
  4. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    SOLD!
    thx for looking
