6 speed tranny?
Discussion in 'Maintenance/Repair' started by ChOpPeD~N~DROPped, May 17, 2008.
  1. ChOpPeD~N~DROPped
    ChOpPeD~N~DROPped Enthusiast
    West of Atlanta!
    94 Extended cab
    Does anybody know if theres a 6 speed tranny that will bolt up to a 20r/22r/e engines?
  2. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    I dont think there is one, but you could call Toyota Auto Parts (TAP) out in California & they would know. The # is 916-631-7100 or 1-800-765-7100
  3. detorra
    detorra Newbie
    Wilmington, NC
    94 stdcab
    any word on this? im interested
  4. grounds671
    grounds671 Veteran
    tampa
    1995 pickup std
    on the celica forums i have read of someone doing so on there late 80's celica using a LS1 tranny with a the bell housing changed. im not sure if i can find it again but ill try finding that topic if it still exist.
    i do know though on on the pirate 4x4 somone long time ago did it for a nissan pickup.
  5. str8_6
    str8_6 Member
    washington
    93 1jz mini
    why would you want 6 speed? just to be different? (just curious)
    probably use a t56 (forget what it came out of)..and have a shop make you an adaptor plate. you'll probably have to get custom clutch setup too though. money will make it work.
  6. JamesD
    JamesD Veteran
    NY
    93 Reg cab
    No it will not bolt up. I read somewhere that it has its own bell to transmission bolt pattern. I believe it was on Yotatech or Pirate.
    James
