5x115???
Discussion in 'Wheels/Tires' started by jetas, Mar 26, 2009.
  1. jetas
    WEll as the title says, will a 5x115 wheel fit? I got an '89 2WD. I kno the center may need to be bored out a bit but will they line up?
  2. MacRib
    MacRib Enthusiast
    San Diego
    90 4runner, 94 standard cab, 90 standard cab STOLEN
    Wheel bolt size for your truck is 5x114.3. You'll also see it as 5x114 or 5x4 1/2. Are the wheels you're looking at off of a different car? Wheels off of a 5 lug Honda, Chevy, Nissan and most Fords will fit(Mustangs, F150's except for the Taurus and Crown Vic's... those are 5x108). You might have to have the centers bored out to fit your hub and you also need to watch for the offset. You may end up with a wheel that sits too far in and rubs the frame or sticks out too far and rubs the body. With a little work you can a lot of different wheels to work, it just depends on the look you're going after. I'm running an 18" by 8" wheel in the rear and they tuck nicely in the wheel well. Good luck!
  3. nvrenufedge
    nvrenufedge Grand Toyotaholic
    Caldwell, ID
    bagged '93 std cab
    Mustang's, Probe's, Crown Vic's & Ranger's are 5 on 4 1/2 (114.3), same as our trucks. F-150's are either 5 on 5 1/2 (135) or a 6 lug on '04 up.
    Chevy's 5 lug are usually 5 on 4 3/4 (120.7), like S-10 & Sonoma.
  4. jetas
    Yea the wheels i was looking at were off of a CTS. They got sold so i got kinda screwed on that deal. I think im going to pick up some Nissan 17s and bore them out
  5. MacRib
    MacRib Enthusiast
    San Diego
    I'm running 18's off of a 350z. I plan to bore them out but for now I'm using a 1/4" spacer and that does the trick. There are hundreds of possibilities to choose from. Another nice wheel out there is on the 2006/7 civic. It's a really nice looking 5 lug 5x114.3, 5 spoke 17"wheel. I'm not sure about needing spacers or anything yet but that wheel tucked into the fender would look pretty nice. Good luck man!
