5speed
Discussion in 'Maintenance/Repair' started by IBeSeeN, Nov 3, 2008.
  1. IBeSeeN
    IBeSeeN Addict
    Harrisburg, Oregon
    89 Toyota
    ok i just bought a 5 speed transmission for my truck and just trying to figure out what one it is... only things stamped into the side of it is
    K30120 Or K3QJ20
    33111-20091
    and a 25
    any help on this would be appreciated he said it came out of a 87 Toyota
  2. Megaglow_Z
    Megaglow_Z Addict
    Benton la
    81 long-bed goodness
    after a lot of reading, i am confused as hell...lol
    But it is MOST likely to be a W56 tranny if it had a 22re in it,or a g52 or g54 if it had a 22r in it.
    look at this chart, it might help
    http://www.4x4wire.com/toyota/faq/parts/
  3. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    if the speedo gear is on the passenger side its mostlikely a W series
    if its on the drivers side its most likely a G series
    pics are always helpful
  4. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    W55 would be my guess...
  5. IBeSeeN
    IBeSeeN Addict
    Harrisburg, Oregon
    89 Toyota
    ok i went ant talked to the transmission shop next to my work they identified it as a w55 what all do i need to change to do the swap from my g40 to the w55 any cutting/ new braces needing made?
  6. IBeSeeN
    IBeSeeN Addict
    Harrisburg, Oregon
    89 Toyota
    ok well i took the tranny over to the shop and was going to have them go thru it... and it isn't a 5 speed i didn't check it before i bought it... so anyone have a use for a W40 tranny? looks like i am back on the search for a 5speed and 50 bucks out of pocket... the guy wont return my calls
  7. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    id go throw it through his window.
    hate false advertising on craigslist.
    you could prolly find one in the portland area if you asked over at www.celica-gts.com
    but a 4 speed isnt that bad compared to a 5-speed. 4th gear in a 4 speed ispretty much the same as 5th in a 5speed
  8. IBeSeeN
    IBeSeeN Addict
    Harrisburg, Oregon
    89 Toyota
    yeah i was thinking about takin it and chuckin it threw his brand new chevy colorado windsheild.... i was goin to upgrade from my current 4 speed to a 5 >< i do alot of hwy driving anymore and hate sittin about 3200-3600 rpm on i5
  9. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    ya i hate my 4 speed as well, and its grinding reverse like a B!TCH
  10. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    if you want to drive up here ill trade ya a 5 speed of your choice for a 4 speed.
    i got w50,55,58's
    did a lil research and it turns out im wrong, 4th in a 4 speed is not the same as 5th in a 5speed.
    http://en.wikipedia.org/wiki/Toyota_W_transmission
  11. V8_TITAN
    Tampa Fl
    89 std cab
    how bout you ship me one of them 5 speeds, and ill send you mine ? your like 3000 miles away and even if I trusted my truck to get me there it would be one hell of a ride lol
  12. B.Y.E.
    B.Y.E. Toyotaholic
    1982 2wd Hilux
    ShoNuff~ Does the W55 bell housing fit on the W58 box? I have my original 4 speed to trade for the W58 if the bell housing from the W55 fits... Let me know!
    Ibeseen~ Before you buy your next trans, take a look at the data sticker/plate cause it'll tell you what trans it has... Good luck on the search!
  13. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    iirc all W series bell housings interchange except the W50. but im not 100% on that info. google a bit to be sure and report back if ya would. or just measure the bolt pattern.
    but any W series meant for any 8r,18r,18rg,20r,22r,22re,22ret will fit on any other r series eng.
    now to finish my coffee and go wheelin
  14. slaytonpdx
    slaytonpdx Member
    89 pickup
    http://www.thetoyotaman.com is a local hilux specialty shop, seems like a cool place to me though ive never bought anything yet... maybe check with him for 5 sp.
  15. IBeSeeN
    IBeSeeN Addict
    Harrisburg, Oregon
    89 Toyota
    i would have looked at the sticker plate but... the truck was totaled he said so he didn't have the body anymore
  16. the_general626
    La Mirada, CA
