5 speed shifter
Discussion in 'Engine/Drivetrain' started by Sal Coloma, Jan 20, 2023.
  1. Sal Coloma
    Sal Coloma Newbie
    Hello everyone this is my first post I’m new here I brought an 86 Toyota extra cab and I’m going to converted from auto to 5 speed manual transmission I have everything needed for the conversion except the 5 speed shifter and the clutch pedal does anyone have one or know where I can buy one I went to 3 different pick your part today and nothing
  2. fred heath
    fred heath Addict
    Raleigh, NC
    You need to identify what model 5 speed you have. Not all shifters are interchangeable.
    For example, the W50 will only work with the shifter installed by the factory. No other shifters will interchange. No aftermarket shifters are available.
  3. jetas
    You can pull off the shift selector off the shaft but you have to remove the tailshaft housing to do this. Its extremely easy, i had to do it on mine when i switched from a W58 to a W55. I wanted to keep the same shifter location and length. Check my build thread to see what i did
