looking to pick up a 4wd short bed for my 2wd short bed pickup. Anyone know if the dimensions are the same and how about the mounting tabs? Any information is greatly appreciated as I am currently stuck in bed with a shattered leg and cant physically o check out the bed. Thanks.
Yeah everthing from the 2wd bed will work, mounting is same also. Only difference is the fender section is wider.
awesome... thanks. i thought the fenders looked a little different... ive got 235 on the back anyways... should fill the void pretty well.
the front mounts could be different but they unbolt from the 4wd bed and can be welded [or bolted but the metal is double thick so better have good drill bits] to the 2wd bed but that is going 2wd bed to 4wd truck you should be ok might have to fab a littl tab between the front two cross rails for the front bed mount or just leave it off six bed bolts should be enough [longbeds have 8 idk about shorts]
