4speed to 5speed swap
Discussion in 'Engine/Drivetrain' started by ryans88yota, Mar 2, 2013.
  1. ryans88yota
    ryans88yota Enthusiast
    olympia wa
    88 2wd base reg cab.
    Im in a little hurry and my search did not prevale. I drive an 88 22r base model standard cab and found someone who has a 5speed out of unknown year came off of 22re 2wd. Its a 100 bucks with money back garentee but before I put forth the effort what do I need to check to see if it will fit. Hes not sure of tranny code but is looking now. Trans mount? Shifter? Clutch\slave/throughout? Anything I need to modify.
    Your advice and help is greatly appreciated on this topic im positive has been covered many times I just cant find my senario at the moment.
    Thank you TM
  2. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    You are going to need the mounting plate and the 5 speed drive shaft.Other then that everything else same same.
  3. Scomber
    Scomber Enthusiast
    Down East
    Ryan, where are you?
  4. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    i think u might have to cut out/modify the shifter hole in the floor -make it bigger. we had to do that on my buddy's 87 - had original 4spd, convert to 5 spd also. but its a minor issue. just get a pair of strong durable tin snips n cut away
  5. ryans88yota
    olympia wa
    Im in olympia washington. And thanks for the info. And he doesnt have mounting plate or driveshaft.. oh well ill wait till I find it all together. No freeway in my daily anyways. Plus buying it would set back my schedualed notch this weekend. But good to know! Now I know what im after
  6. Scomber
    Scomber Enthusiast
    Down East
    Right. I think I have that drive shaft ('86 22R 2WD, Standard Cab, Standard Bed, W55) but you're a long way from here.
  7. ryans88yota
    olympia wa
    Well ur down east apparently and im up north so id say yea ill keep my eyes open at the wreckers. But thanks a bunch for the offer
  8. 22r
    22r Veteran
    Maui
    if you have a 1piece d-shaft on the truck you can use that. on my swap all i had was 5spd trans. the shifter from the 4spd, the 4spd d-shaft, and a custom trans mount its easy i used two pieces of angle iron to extend the 4spd mount. i forget if i made the hole bigger. also the reverse light switch wiring might be diff but its only two wores.
  9. ryans88yota
    olympia wa
    Thank you. I do have the one peice ds. :) I will call him up and go get it! Is the shifter as easy to swap as it seems?
  10. 22r
    22r Veteran
    Maui
    yup, really easy its just 4 10mm head bolts and the shifter retainer plate comes out along with the stick. but besure to change both bushings when replacing. when i have the chance i can snap some pics of the mount i made. but other than that its really easy.
  11. ryans88yota
    olympia wa
    Awsome man uve been a considerable amount of help! I think my headgaskets starting to go so 5speed may be on back burner but id def. Like to see ur pics and a discription of why the custom plate. Such as how does the 5speed mount differ from the 4. Thank you.
  12. 22r
    22r Veteran
    Maui
    no problem, to be honest i think of myself as a noob compared to some other guys on here. Im currently off island so when i head back ill try to document as much as i can.
