4spd to 5spd tailshaft u-joint
Discussion in 'Engine/Drivetrain' started by Tom Chitwood, Nov 27, 2024.
  1. Tom Chitwood
    Tom Chitwood Member
    Pine Knot KY
    1975 Hilux
    I swapped a 5 speed out of a 1991 pickup into my 1975 pickup. I used the tailshaft slip yolk from the 91, but the u-joint is larger than the one on the 75 drive shaft. Is there a conversion joint I can use?
    1” to 1.1375”
    Thanks, Tom
  2. Tom Chitwood
    Tom Chitwood Member
    Pine Knot KY
    1975 Hilux
    No ideas?
  3. RetirementToy
    RetirementToy Enthusiast
    Vallejo,CA
    1988 Toyota Extra Cab 2WD
    Call a drive line shop!
    fred heath likes this.
  4. fred heath
    fred heath Addict
    Raleigh, NC
    Second a driveline shop. You might have to have a new driveshaft fabricated if there are no available adapters to modify your existing shaft.
    I had to do this when I installed a GM 14 bolt rear axle on my motorhome.
    Erwin Merida likes this.
  5. Tom Chitwood
    Tom Chitwood Member
    Pine Knot KY
    1975 Hilux
    There is no conversion joint available, I contacted Moog. I am having to change the end of the driveshaft to the larger yolk. Oh well.......typical for me..........
  6. Tom Chitwood
    Tom Chitwood Member
    Pine Knot KY
    1975 Hilux
    Swapped the end of the driveshaft and it bolted right up. Had to redo the trans mount, trim the floor opening slightly, shorten the clutch slave cylinder rod 1/2" and added a B&M T handle shift handle for ALL the extra horsepower.
    RetirementToy likes this.
