4runner bucket seats
Discussion in 'Interior/Electronics' started by NMTOY, Aug 12, 2009.
  1. NMTOY
    NMTOY Member
    NM
    92 extracab, 86 4runner
    I found a 4runner being parted out on CL last week and bought the buckets for $50.00. The drivers seat has some wear so I got some covers from Ebay for $50.00.
    I installed the seats today. The install is pretty easy, I had to make a bracket for the drivers side right front bolt but it's pretty easy. I did the same swap on my old 90 4wd.
    I also bought the seatbelts and installed the drivers side.
    sorry about the small pics, I'm having problems with Photobucket.
  2. Toyo Trucker
    Toyo Trucker Addict
  3. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    looking good
  4. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    What kinda steering wheel is that? Doesnt look stock. Is it removable?
  5. nvrenufedge
    nvrenufedge Grand Toyotaholic
    Caldwell, ID
    bagged '93 std cab
    Really!? My 92 4runner seats bolt right in.
    Looks good!:waytogo:
  6. NMTOY
    NMTOY Member
    NM
    It's a Grant GT wheel, not removeable.
  7. NMTOY
    NMTOY Member
    NM
    The right front hole on the drivers side that lines up with the seat bracket is not threaded. The threaded hole is about 1 1/4" to the left so I just made a simple bracket.
  8. nvrenufedge
    Caldwell, ID
    bagged '93 std cab
    Nice! I must have lucked out then, mine's threaded. The only thing I had to do was mount the seat belts on top of the rear inner mount. Cause where the 4runner and some of the trucks seat belts mount to the tranny hump, the holes aren't there on my truck.
  9. NMTOY
    NMTOY Member
    NM
    I ended up drilling a hole in the trans tunnel for the drivers side seatbelt opposite the passenger side.
  10. MacRib
    MacRib Enthusiast
    San Diego
    90 4runner, 94 standard cab, 90 standard cab STOLEN
    Looks great!
  11. IronNam
    the XLE Camry has leather powered seats... how will i wire this stuff?! haha
  12. oahu grown
    Hawaii
    92 Extra Cab
    I suppose you could tap a power wire, acc or ignition or something like that, then just ground out the ground wire.
  13. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    yep. i would run a large (10-12g) wire through a fuse holder from the battery and then make a solid ground to the floor. most electric seats just need 2 wires. others are usually for the buckle buzzer.
  14. dwnshfter
    dwnshfter Member
    do those just bolt right in?
  15. IronNam
    not really, i placed my camry seat and the brackets arent close to matching. It may take some custom bracket fabrication to get them in.
    if i had a welder, i'd just chop off the old mounts and weld in new ones.
    I know for sure camry headrests plop on my 60/40 bench lol
