4 speed rear end
Discussion in 'Engine/Drivetrain' started by Micro Machines, Jul 11, 2015.
  1. Micro Machines
    Micro Machines Member
    Portland OR
    92 xcab 22re
    I have a 90 22r 4 spd and it has a 8"rear end with 3.07 gear ratio. I have no idea if that's right or I completely read the numbers on the inside door sticker wrong, but is this worth swapping into another truck for later upgrade in gears? Any opinions is greatly appreciated and corrections are welcome too.
  2. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    It's a pretty bomb proof axle and there are many better options for lower gears readily available from the factory out of 4 wheel drive trucks.
  3. Micro Machines
    Portland OR
    92 xcab 22re
    Oh ok but this 8" is on a 2wd truck. That's the part that confused me, I didn't know 2wd came with 8" rear ends
  4. White Trash
    Eastern WA
    Correct. The 8" is standard on many 2 wheel drive trucks when the factory spec'd a certain gear ratio. I've had '76, '78, '87 and '89's with 8" diffs.
  5. aaron_sk
    aaron_sk Enthusiast
    Tacoma, WA
    '94 Regular cab
    Was it only the higher gear ratios that had the 8" axle?
    FWIW I would love to find a 3.07 axle. I could do 80 comfortably with that rear gear!
  6. White Trash
    Eastern WA
    The early trucks got it with 4.10's when they had a 5 speed, the later trucks with 4 sped got them with 3.07's due to no overdrive. There are factory V6 3.42 8"diffs available too.
  7. aaron_sk
    aaron_sk Enthusiast
    Tacoma, WA
    '94 Regular cab
    Nice. I had always assumed the 4-speed trucks got the 7.5" with 3.42's same as the base-model 5-speed trucks.
  8. Micro Machines
    Portland OR
    92 xcab 22re
    So would that rear end be better the one that has a 7.5 with 3.56?
  9. White Trash
    Eastern WA
    The 7.5 is better suited to sending to China to be returned to the US as matchbox cars. :lol:
  10. Micro Machines
    Portland OR
    92 xcab 22re
    Lmao, got it thanks guys!
  11. raylcc
    raylcc Addict
    Denver, CO
    So THATS why the axle's on my Matchbox cars were always bending as a kid! :waytogo:
