Hi, I am in the planning stage to swap from a 4-speed to auto. My question: is there a difference in the lengths between the 4-speed and Auto? Can the driveshaft from the 4-speed be used in the Auto? Has anyone done this swap before? Thanks for any info.
If the trannys in the 84-88 are like the 89-95 then the trannys are different. I had a automatic in my 91 & switched it to a 5-speed...the automatic is longer & the shaft was shorter then the manual drive shaft. So in short if you do the swap then get the drive shaft too!
simple cure is to find a truck at a junkyard with the layout you want but still the same truck. like: if you have a 88 short bed, you need to find one with a auto. but you may get lucky. for me it turned out that a 85 supra 5 speed was the same length as a 74 A40 3 speed auto. either way having a driveline shortened or lengthened is fairly cheap.
not sure, i didnt do any cross comparison. i only have w50's and w58's lying around, and they are the same legnth. like i said i got lucky. but a tape measure will answer your questions pretty quick
