I wanna do a 4-link rear for drag racing purposes... Any input as to simplicity and function is greatly appreciated! Thanks! '82, SWB, 2WD...
if your using it for drag racing, make sure to use a forward 4 link. it will properly force the rearend to the ground under acceleration. parallel 4links with a panhard seem to be the norm for racing since you'll run coilovers and the axle has very little travel.
also alot of guys use mounts that have mulitple holes on the upper and lower. to add adjustability to the geometry. as well as an adjustable end on atleast one end. to change the length which changes various geometry.
if you are gonna drag it i would do a good forward face 4 link, relocate the gas tank to the rear. since i placed my tank back there the truck feels better balanced and definately can launch..... but i also have the rear locked if you dont wanna relocate the gas tank, you can do 2 forward links and a panhard bar, or 2 forward links and an upper wishbone offset link.
I'd have to narrow my frame for that type of setup correct? I was thinking of doing something like the 4X guys use... Triangulated type?
if your gonna drag race it a parralel with a panhard.. will work best, the 4xs use triagulated for more articulation, wich you dont need going straight..
Amy pictures? Anyone know biggest rear drag radial in a 15" that will fit the rear of a 1986 2wd? No frame mods.
