4.3 Swap
Discussion in 'Engine/Drivetrain' started by BUDRO, Nov 10, 2011.
  1. BUDRO
    BUDRO Member
    Beautiful S.C.
    2007Taco Xtra cab, 1987 Reg cab ,1985 Turbo Xtra cab
    Have an 85 Xtra cab 2wd sitting with bad motor. Have a 2002 Blazer with rebuilt moter and new trans sitting in yard got rear ended. Complete vehicle! How hard is the swap ? Will it work? If you can drop a small block why not 4.3.
  2. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    You could swap in the 4.3. Its been done lots with the 4wd guys
    But I wouldnt do it even if I had your parts truck. They dont make that much power, and the PATS system is tricky to bypass.
    Lots of work for little power.
